DaveHo
- Dec 11, 2001
Background. First let me say that I'm fairly happy with the sound of my current setup. But it's been a while & I'm getting the itch to change things up.
Current setup:
Speakers - Paradigm Studio v2, 100's, CC, ADP's, Studio 20's
Amps - Front: Acurus A200x3, Sides: Parasound HCA1000A, Rears: Audiosource Amp Two
Pre/Pro - Outlaw 1050 with the internal amps powering my multi-zone system through a speaker switch box
I'm leaning towards replacing the 1050 with an Outlaw 990. Here are the two amplification scenarios I'm considering.
1) Replace all the amps with the Outlaw 7700. I'd probably keep the Audiosource to power the multi zone system through the 990's zone 2 output.
2) Keep the Acurus & get an Outlaw 7125 for the sides & rear. Use the extra 3 channels on the Outlaw to power some bass shakers & the multi zone system.
Primarily I'm looking for feedback on the sound of the Outlaw 7700 vs the Acurus. I know several here have or had the Acurus & I'm hoping for some comparisons. Couple of things to note. I like to "rock out" regularly. I definately need the extra power from the Acurus or 7700 for the front soundstage. My cable runs are fairly short, but if I get the 7700 I am planning on using the balanced connections.
So, is the 7700 a step up from the Acurus, step down, sideways move?
Thanks for any input.
-Dave
Current setup:
-Dave
