mastermaybe
- Aug 7, 2007
- james
alright lets just get right to the point:
1. I'm spending $2000-$2200.
2. I am definitely securing 1080P...please do not try to sway me otherwise with the following: "are u aware that most broadcasts are 720"..."there's not a big difference between the two"...blah blah blah. The fact of the matter is I'll likely have this tv for at least 5 years, and I want as much technology as I can afford. I mean the aforementioned respectfully, but I've grown weary of salesmen trying to force my hand into 720.
3. I am leaning strongly towards a rear projection as, similar to the thinking above, I would like the LARGEST tv I can afford (my viewing room is also rather large...anywhere from an 10' to 20' viewing distance)
4. I would consider a smaller lcd/plasma tv ONLY if these conditions exist:
1. A reasonably significant (I realize this is a relative term, but I feel folks on the this forum are capable of making the distinction)
2. A marked increase in general reliability. I am not concerned w replacing the projection bulbs on, as this is NOT a reliability issue)
5. Does 1.3 hdmi matter in regards to video? From my reading it appears that it does NOT. I have my HD audio bases covered. That said, it appears that the only major difference between many manufacturers DIRECT model replacements for the next year is the number of HDMI inputs and the 1.3 compatibility. I could save a handsome sum by choosing a current model if the 1.3 is inconsequential to video/image quality.
Brass tacks:
Right now I"m between a MITSU WD-Y65 (1080P 65") and the SONY SXRD 60 A 2020 (current model i believe, upgrade from the 2000?). To be really honest, the mitsu is only in the running because of the larger screen size (marginal, I know) and color quality (which could be in my head too). I guess I feel very similar to the majority of consumer reviews I've read in regards to the sony: i love the deep blacks (especially for a projection), its excellent contrast, and it lacks many of the burn-in, screen door, and rainbow effects that other units suffer from.
I guess in the end, i would buy this tv tomorrow if I had to choose.
advice, experiences, and other suggestions would be great! 2 grand is 2 grand!
thanks,
james
Brass tacks:
thanks,
james
