Jim Carr
- Dec 23, 2001
I finally got this bad boy.. hooked it up with basic component cables and coax digital to my RCA F38310 widescreen HDTV and my Onky 898. The picture is INCREDIBLE! But the most improvement came from the sound believe it or not. This thing sounds WAY better than my old Sony DVD player. I didn't know a DVD player could make such a difference in sound?
Now a couple questions... I heard that you could adjust the height/width of the display to fit my screen exactly, for instance when my TV locks in full mode and I need to adjust the format a bit. I thought you could do that with the RP91 but I don't see it in the manual.
Also... I have it hooked up with my coax digital cable to my Onk, is it better to hook this up with the 5.1 RCA channel hookups to my Onk? I don't know the excact terms (big fat newb) but you know what I mean.. the seperate channel RCA connecitons. Is that better than digital coax cable? If so, where can I get good ones that won't cost me an arm and a leg?
Good component cables that won't cost me an arm and a leg?
thanks guys!!
Jim
thanks guys!!
Jim
