Cees Alons
- Jul 31, 1997
- Cees Alons
(1) For Audio 5.1: the usual shielded cables (often "stereo", banana plug) are fine. You could use three pairs (L - R, C - S, RL - RR). It's audio at the normal pre-out -> amp-in level.
(2) For video: set your player to the physical ratio of your TV screen (4:3 or 16:9, whatever way it is called).
Then, depending on your TV-set, it may be necessary to switch the TV-set by hand (if your TV has an "auto" setting for image ratio, try that one).
Mine (a Samsung 42" 1920x1080) has "4:3", "16:9", "zoom", "4:3 wide". I NEVER use "zoom" or "4:3 wide". The last one distorts the image; the zoom will blow-up a 480-image, but not as beautiful as the HD-A1 does.
I only need to use the 4:3 setting with my cable set-top box, not with the player, now I'm using HDMI, because the player will output an SDVD image upscaled (and very good upscaled) to 16x9.
If you don't use HDMI, it could be necessary to switch the aspect ratio of your TV-set manually (with the remote).
If your TV generates grey bars next to 4x3 images, that's bad (they do it to avoid burn-in if much of your programs would be 4:3). Mike Knapp once published a simple solution: he used two (or even 4) black foam mattes, fixed to the TV with velcron and I remember several members reporting visually very pleasing results (even the image looked better - more brilliant - that way, they said). (Of course, this may mean that you have to get up from your couch between different programs.)
Cees
Cees
