Jeff Elliott
- Nov 5, 2002
Greetings to all! Would like to build my own sub(s) using the Sonotube enclosure. I've done several searches here on this topic and have learned a lot. Now I need your help with my specific situation.
About me: I used to build (not design) subwoofer enclosures as a custom car audio installer while in high school and college. I have good woodworking skills and have probably inhaled enough MDF dust to make the enclosure I seek! I have plenty of woodworking tools to complete the project.
About my room: 16' X 17' bonus room with knee walls. Used 70% home theater and 30% two channel. Speakers are Divas: 6.1's, C3, and R3's. Currently looking for amplification and processing.
What I've considered thus far:
-Enclosure Size: Would prefer to use 18" tube. Would be willing to use 24" if necessary. Would like to stay below 48" tall if possible.
-Driver: Would like to use bottom-firing sub. Indifferent between bottom or top port. 12" or 15" driver was what I had in mind, but will listen to any suggestions. No name brand loyalty formed.
-Amplification: Thought I would use something in the pro line... Maybe QSC or Mackie as I have wholesale access to these lines. Plate amps are fine two, feel free to suggest your favorite! Will need some crossover capability but have no idea what to choose.
*-Budget: Would like to keep it between $500 - $1000 if possible. I was planning to buy a used SVS 16-46 and Sampson S700 for about $550. After a bit of reading, I figured I could best this option for equal money or blow it away for a few hundred more. Am I way off base here?
*-Ports vs. Radiators: No real preference here. Whatever is best and provides the most value.
I have downloaded a couple of the enclosure design tools and have played with them some. What I am really seeking is a tried and true enclosure / driver combo that I can build. Since so many of these enclosures have been built by all of you, I would like to avoid re-inventing the wheel. I would also consider building two subs using smaller drivers if that will make more since. Thanks for any suggestions you can provide!
Jeff
Jeff
