Currently using an an antiquated 10 plus year old Denon receiver which has served me well to date but i believe it is time for me to upgrade. Below is what i am looking for in a receiver
1. Wi-Fi Capabilities - need to know the plus and minus points for this feature. what is it mainly used for etc.
2. My TV sound is horrible so i play all my audio via the receiver. Currently i have a HDMI cord connecting the cable box to the TV and i have a optical cable connecting the cable box to the receiver for sound. The sound that i get is dolby 5.1 which is fine, but is this the best way to connect? i thought that in the newer receivers the HDMI cable gets connected to the receiver and then the TV. I am lost all i need is the best sound to come out of my receiver. My TV is a Panasonic plasma 65" about 7 years old. i am happy with the picture and don't see the need to upgrade as yet unless someone provides a good reason to do so.
3. Since i watch a lot of on line content i connect the computer to the TV via a HDMI cable and since my TV sound is horrible i connect the TV to the receiver via a cable, i forget the kind of cable i believe it is a RCA but not sure. The sound that i get from the receiver is prologic II and not Dolby 5.1. I am sure that the newer receivers can get the 5.1 audio but don't know. i need the sound quality to be better than what i currently get HELP!!
4. Ports for connecting ipod/iphone/ipad etc.
5. Airplay - need info on this. i think this is to play music wirelessly from the iphone/ipod etc but not sure
6. Looking for any other suggestions as far as what other ports, does the receiver have to be compatible with 4k etc, what processors should the receiver have etc. i want a receiver which will suffice for at least 3 to 4 years as far as technology is concerned and not become obsolete in a year or so.
7. I currently have a wired 5.1 setup and am fine with it.
Thank you all in advance
