World Wide Stereo
Need help hooking up a h/k 525 (1 Viewer)
Dom P
I want to hook up my sub and use my TV speakers for highs until my fronts arrive. What's the best way of doing it?
Denon 910
Sanyo 32" HDTV
H/K 525
UFW-10
728x90
Wayne Ernst
Dom,
Unless you can get to the speaker connections on your TV, this process is virtually un-doable. Plus, even if you do get to the connections, keep in mind the TV speakers are only designed to handle a few watts of power. I'd recommend waiting until your main speakers arrive. Seriously.
If you're in a real pinch for some sound - and to start using your receiver, head to CC or Best Buy and grab a cheaper pair of Sony speakers. They typically have these on sale for $19 or so each. This would be about the most simple solution at the moment - other than using a pair of headphones.
Similar Threads
jrharris
