I really love Beverly Hills, 90210 but can't watch with replaced music. I bought the DVDs (already knowing about the music issue) but watched the first 2 episodes before I realized I couldn't take it anymore.
I have a project to solve the music replacement issue. Same idea as the Roswell restored project. I already have the original audio for all episodes except the pilot.
Does anyone have the original, Soapnet, or TVtropolis 2 hour pilot episode (Class Of Beverly Hills) recorded on VHS in Hi-Fi stereo?
If so, can you record just the audio (with commercials is ok and preferred) and upload to my cloud drive (PM me for the link). It has to be HiFi stereo. I can easily hear the hiss and dropouts of standard linear audio tracks.
Please use at least 44.1Khz sample rate and 16bits (levels set ok so there's no clipping). Most recording programs won't record more then 2GB per file, so make 2 files if needed. You can use 24bits at 48Khz if your sound device will do it. Compressing with lossless .FLAC, .ALAC, .WV (wavpack), .APE would be ideal, but .MP3 of 192Kbps, or .AAC (.M4A) at least 128Kbps is ok too. MP3 of 128Kbps or AAC 96Kbps is the minimum before compression artifacts become obvious. .WAV or .AC3 is fine too (I can handle any format).
If you have it in digital already, say a video file you got somewhere, I can handle that too. Google for the free program Mediainfo to check the audio format and bitrate. If at least 128Kbps stereo or 2 channel for the audio, that'll work.
If you no longer have a HiFi VCR, I do have a recently refurbished prosumer editing HiFi S-VHS deck, but would rather not go the postal borrow, dub, return tape to you route as I wish to remain anonymous.
Again I only need the pilot episode. I'm not looking for DVD audio, but a recording using a VCR of any of the 4 TV broadcasts that had all the cool music. And if you are truly elite, you did the Dishnetwork trick around 2005 and recorded episodes from Soapnet (I did that starting in 2006 but they never played the pilot episode).
Can anyone help?
Can anyone help?
