Marantz sr7200 (1 Viewer)
Harborg
bob
How to get digital audio2 input working. connected to my LG tv didital audio out.
B-ROLL
Bryan
Welcome to the Forum!
This should be the back of your receiver> Is there a reason you are not using the HDMI out?
If you are using digital out, are you using a RCA cable (metal points) on both ends or an optical cable (part clear on both ends)?
If you are not using HDMI you will have to change the audio out setting on the LG to the Digital Out in the set up menu for your TV set
balajipackersmovers
