mike_doyle
- Nov 22, 2002
I have narrowed it down to these two(three) receivers...
Marantz SR 5200 ( 6.1, 85W x 6 ) Harman Kardon AVR 320 (7.1 capable 55W x5 ) or the newer AVR 225 ( 55W x5)
I can get all for around $450 US. ( I know they can be found for less in the states but up North that is the best I could find) I am trying decide which to get. I am going to hook up an expressvu 4700 (via fiber optic(toslink) or coax not sure yet). DVD player (again via toslink or coax) a VCR and an XBox (Toslink only).
I listen to music/movies(television) about 50/50.
My speakers are all paradigm. 3SE's up front, CC350 for center and ADP 170 dipoles for rear.
Questions:
1) I am leaning toward the Marantz but I am a little skeptical about the build quality. (Read reviews about popping noises etc.)
2) I am having a hard time to decide between the AVR 225 and 320 from H/K. I know the 320 has component switching(Not an issue for me right now)and 7.1 channel capability with separate amp.
Also all 3 only have two fibre optic and two coax (on back panel) so I will have to switch either my DVD or satellite to COAX. which should I switch? I listen to the sat more but mainly in prologic and stereo. Very rarely DD 5.1 (some PPV's). I use the DVD for DTS, DTS ES(not yet) and DD 5.1 exclusively? Which component do you guys recommend I switch to COAX.
Mike
Questions:
Mike
