Mark Giles
- Aug 30, 2002
Ok, here's what happened. Everything was working perfect for 2 weeks since I bought everything. I turned my computer off, removed a extra unused NIC card I was going to use for XBOX live(I have onboard LAN also) and turned my computer back on. The Windows startup tune started, so now im in windows. I click IE to browse online then all of a sudden, my speakers makes this pop noise followed by a faint steady hum. I turn off my speakers and notice that my computer was frozen. Couldn't move my mouse or anything. My desktop image is still displayed at this point. So I cold boot and now my moniter wont turn on.
So far I have installed another video card with no luck. Same results with no display.
My power supply seems fine, the lights light up on my drives and even the light on the motherboard is lit.
The fans that are plugged into my motherboard are running.
I have uninstalled all cards and drives except for the video card and memory to see if I get any image(yes, my moniter is plugged in).
I even tried clearing the CMOS jumper.
There are no system beeps from my bios at all.
After I finish writing this, Im gonna try installing a different CPU in the motherboard. But wouldn't I get beeps representing a CPU problem?
Is my 2 week old MB gone? Anything else I can try?
My setup:
AMD XP 2200+
ABit AT7-MAX2 w/onboard Lan
512 DDR PC3200
Geforce 4 Ti 4200 128mb
Creative Labs Live!
Additional NIC card(which I took out)
30 and 60GB Maxter HDD's
CDROM and CDRW
ummmmmm and
Windows XP Pro
My setup:
AMD XP 2200+
512 DDR PC3200
Creative Labs Live!
CDROM and CDRW
ummmmmm and
Windows XP Pro
