I want to send signals from a CD player and CATV over the same coax 75ohm cable! (1 Viewer)
Hi!
I have speakers on the living room connected to a receiver located at my HT room. I'm controlling a single DVD/CD player and the receiver using the Radio Shack wireless remote extender. Now I want to place a CD changer on the living room so I can see the player's display. The CATV instalation (analog) came from the street to the living room connecting to a splitter that left a connection on the living and send other cable run to the HT room.
I want to know if I can connect the living room coax cable to the CD changer and then put another splitter on the HT room to connect to the TV and the receiver. An A/B switch will be better?
I will appretiate your help
I forget to mention that I want to do this, because I have concrete walls. To reach the HT room I have to drill at least 3 walls which is not an easy task.
charliewonka
SVS Outlet Sale
