Chuck C
- Jan 6, 2001
2003 Toyota 4Runner SR5
Just take a look at it...pretty big huh. Well you're right. The 4th generation Toyota 4Runner is bigger and heavier than ever. It's also more powerful!
POWER PLANTS
The new 4Runner is based on the Prado (foreign, 7/8 scale Land Cruiser) whereas past 4Runners were SUV versions of Tacomas*. The base engine is a 4.0L V6 rated at 245hp/283-lb-ft. This engine choice is coupled with part-time 4WD. The other engine option is the common-to-many-Toyotas 4.7L V8 at 235hp with an generous 320lb-ft of torque. 4WD works full time with the V8.
TRIM
The 4Runner is available in 3 trims. The basic SR5 with plastic body moldings and 16" wheels starts at $26,000. The SR5 Sport adds body refinements including a hood scoop and 17" alloys. This option will run you about $33,000. Finally, the Limited with all the goodies including heated seats tops out at $40,000.
ALPHABET OF FEATURES
-HAC (Hill-start assist control): applies brakes and manages torque during uphill strides
-DAC (Downhill assist control): kicks in at speeds under 18mph and reduces speed to 2-4mph during demanding downhill driving.
-VSC (Vehicle skid system): electronically controlled braking/stabilizing system.
-X-REAS (X-relative absorber system): transfers power between diagonal shock absorbers. Toyota.com has a great Flash demo that explains X-REAS in more detail.
Got all that? Lately, HTFCotWs have been weak, so enjoy this one.
*From Car&Driver magazine
POWER PLANTS
TRIM
