How do I get Sirius XM radio on my Yamaha RX-A3070 receiver? (1 Viewer)
Walt H
How do I get Sirius XM radio on my Yamaha RX-A3070 receiver? This receiver is supposed to have Sirius XM built-in. A google search states "Select On Screen on your Yamaha remote, then select Sirius XM", but I don't see that as an option within the on-screen menu (unless I'm overlooking something). Any help would be appreciated. BTW, the pdf manual has no mention of Sirius XM radio yet on the Yamaha website the features states Sirius XM.
David Norman
Similar receiver, but it seems to be under the MusicCast App.
Is that set up already?
Unfortunately I also found some posts saying an update to the Sirius streaming service prevents some older receivers from working with Sirius at all
Walt H
Unfortunately I also found some posts saying an update to the Sirius streaming service prevents some receivers from working with older receivers.
Thanks! I did find it under the MusicCast App as you stated. Problem solved.
Nielmb
