Angelo.M
- Aug 15, 2002
After my car was about 3 years old, I began to notice that the (factory) left front speaker would drop out occasionally. Tweaking the volume knob on the radio (factory as well) would usually correct the problem. After upgrading to aftermarket speakers and CD deck, the problem persisted.
Now, it happens more often. In addition, the front right speaker occasionally drops out as well. Again, tweaking the volume control brings it back, sometimes only temporarily.
I assume that there's a problem in the connection between the head unit and the speakers, as the problem happened before and after the head unit and speakers were replaced. How difficult is this to fix? Should I let a pro do it?
Thanks, in advance...
