FS: Technics DVD-A10 (DVD-A player) and matching Technics SA-DA10 Receiver (1 Viewer)
Ivan P
I am selling Technics DVD-A10 DVD-Audio player and maching Technics SA-DA10 receiver in champain color, both are in perfect condition I will attach actual pics later today, but I found some on the web.Both of them comes with remotes and all cables the Receiver doesn't have the original box but will be very well pack.
Buyer will pay the actual shipping.
Here is some of the spec of DVD-A10:
Plays DVD-V (DVD-Video) and DVD-A (DVD-Audio)
DACs: 10 Bit Video; 192 kHz - 24 Bit Audio
MFR: 2 Hz - 88 kHz (DVD-A), 2 Hz - 44 kHz (DVD-V), 2 Hz - 20 kHz (CD)
Outputs: S-Video, RCA Coaxial Composite Video, Coaxial RCA Component Video (Y, PB, PR), Coaxial RCA Digital Audio, Optical Toslink Audio, Coaxial RCA Two-Channel Analog
Audio, Coaxial RCA 5.1 Analog Audio
Size: 5" H x 17" W x 10 3/4" D
Weight: 19 Pounds
Here are some websites with reviews for that player:
http://www.3dsoundsurge.com/press/pr223.html
http://www.hifichoice.co.uk/review_print.asp?ID=1016
Tehcnics SA-DA10 (DD 5.1 DTS)
Here are some sites with reviews
http://www.hifichoice.co.uk/review_print.asp?ID=1038
Specification:
Amplifier
Stereo Mode Power Output 100w per channel x 2, into 6 ohms
Surround Mode Power Output 100w per channel x 5, into 6 ohms
4-ohm/8-ohm Switching Yes
Surround Sound
THX Processing No
Dolby Digital Decoder Yes
DTS Decoder Yes
Dolby Pro Logic Decoder Yes
Digital Signal Processing (DSP) Yes
DSP (DAP) Modes Yes
Theater Modes Yes
Conveniences
Multi Room/Multi Source Audio Output No
Input Selector 5 Audio, 4 Video
AM/FM Presets 30
DVD Control Yes
Digital Satellite System Control No
Surround Control on 5.1 Channels No
Remote Control Universal
Connections
5.1 Channel Inputs Yes
Subwoofer Output 1
Surround Back Speakers No
Rear Channel Stereo No
Audio Inputs (RCA) 9
Audio Outputs (RCA) 3
A/V Inputs 5
A/V Output 3
S-Video Input 2
S-Video Output 1
Component Video Input No
Component Video Output No
Optical Inputs 3
Optical Outputs No
Coaxial Inputs No
Coaxial Outputs No
RF Connector Yes
Front Audio/Video Input Yes
Headphone Output Yes
Video Monitor Output (S-Video) Yes
Preamp Output No
USB Connector No
A/B Speaker Selection/Connectors Yes / Large
Control Protocol No
FM Tuner
Frequency Response
IHF Sensitivity
50dB Sensitivity Mono/Stereo
FM Alternate Channel Selectivity
FM Frequency Response
FM THD @ 1kHz Mono/Stereo
FM S/N Ratio Mono/Stereo
General
Power Requirements 120v AC, 60 Hz
Weight 26 lbs.
Dimensions (WxHxD) 16.9 x 6.2 x 14.9"
Features:
The SA-DA10N DVD Video and DVD Audio Ready receiver incorporates Variable Gain Control Amplifier (VGCA) technology that achieves a 113dB signal to noise ratio; MOS-FET circuitry for excellent sound quality with power bandwidth up to 70kHz; and a Digital-To-Analog Converter (DAC), based on MASH technology for 192kHz/24-bit DVD-Audio use, to deliver astounding sound - enriched with the nuance, warmth and subtle overtones of a live musical performance. Features include built-in Dolby Digital and DTS Decoder, TA-KE II capacitors, Class H+ amplifier circuitry, Sound Field Control (SFC), 6-channel discrete outputs, subwoofer out, front A/V inputs and universal remote control that will allow you control of many TV/VTR/DVD players.
Key Features
• VGCA (Variable Gain Control Amplifier) and MOS-FET (Metal Oxide Semiconductor Field Effect Transistor) Circuitry
Renders the SA-DA10N uniquely suited to deliver the highest quality DVD-Audio. By improving power bandwidth and contributing to outstanding sound quality linearity, MOS-FET allows the receiver to reproduce the broad spectrum of frequencies for which DVD-Audio is known. A S/N Ratio of 113dB and frequency response up to 70kHz are standard operating procedure for the SA-DA10N. That means music from DVD-Audio discs will take on the rich, clean sound one would expect from a live performance.
• TA-KE II Capacitors
Japanese bamboo fiber in the separator provides a natural sound field, transparency and freedom from coloration.
• Home Theater Mode
Equal high power output of 100w (20Hz - 20kHz, 6 ohms, 0.9% THD) per left, center, right, left surround and right surround channels.
• Powerful Stereo Mode
100w per channel (20Hz - 20kHz, 6 ohms, 0.9% THD)
• Class H+ Amp Circuitry
The receivers use Class H amplifier circuitry to ensure smooth, quiet and, most importantly, cool performance - no matter how demanding the soundtrack. Unlike a traditional amplifier, which uses a single power supply, or "rail", Class H incorporates two rails working together. The higher-powered rail only goes to work when loud scenes, explosions or other spikes in audio demand it. Class H also boosts dynamic headroom to 2 dB, with power to spare for accurate delivery of dynamic audio passages.
• Technics DVD Audio/Video Player
Unified design with aluminum front panel and light-blue LED.
• Anti-Vibration Construction with THCB (Technics Hybrid Construction Base)
These design elements virtually eradicate noise-causing internal and external vibrations.
• High Quality Construction Power Transformer
And volume control.
• VGCA Mode
Bypasses potential noise-causing circuitry to provide a pure signal path.
• Multi-Channel Multi-Drive Design
Realizes high-grade stereo by-amp operation.
• Additional Features
• Built-In Dolby Digital and DTS Decoder
Converts the encoded digital signals to 6 channels of analog audio (5.1) for spectacular home theater sound and performance.
• Six-channel Discrete Inputs
For connection to a DVD-Audio/Video player. (Besides its ability to decode Dolby Digital and DTS soundtracks.)
• Dolby Pro-Logic Surround Decoder
• Sound Field Control
Sound field control function creates a surround sound field from 2-channel stereo sources, such as a CD or a cassette tape. This function uses the front, center and surround speakers to simulate a live performance atmosphere. Choose from HALL, CLUB, LIVE, THEATER and SIMULATED SURROUND (for mono source) settings.
• Universal Remote Control
Ready for many TV/VTR/DVD players.
• Subwoofer Output
For extended bass reproduction.
• Large Speaker Terminals
Help preserve signal quality.
• 5 Video and 4 Audio Rotary-Type Input Selectors
• Gold Plated Input Terminals
• 3 Digital Inputs (Optical)
• Front A/V Inputs
• Tape Monitor Switch
• Quartz Synthesized Digital Tuning System
• Direct 10-Key Tuning
By remote control.
• A and/or B Speaker Selectors
• Low Impedance
• Dimmer Switch
For FL display (by remote control).
I still need don't know how much I will ask for them, but any good offer will be consider.
Please PM me, I would prefer to sell them together.
Let say $350 for the DVD-Player and $350 for the receiver or $650 for both.
I will post them on Ebay if I don't sell them
Philip Hamm
I have an A10 player and am familiar with the reciever. This is great gear, folks. The one year that Panasonic/Technics played with the idea of a higher end brand on par with Pioneer Elite and Onkyo Integra. A fantastic receiver. I wish mine was broken so I could pick up on the deal. :)
Ivan P
I posted them on Ebay,
Still if you want them let me know and I will cancel the auction.
foster2292
