Serge Breton
- Oct 21, 2001
I have owned my projector for 2.5 years since purchased new. The model is a Mitsubishi LVP X-70 LCD projector and was manufactured in 2000. Makes a perfect home theater projector but can be used for business purposes also. Maximum 1280x1024 resolution (1024x768 native), very low 350 hours of use one the 2000+hr bulb. Fully HDTV compatibly, well reviewed with an excellent image on an 8ft wide screen. Included is the projector, remote with laser pointer, nice carrying case, Dalite screen and the included cables also. Only selling to upgrade. Here is some detailed info:
Features
1100 ANSI Lumens
Ultra Compact/Super Lightweight Design
CineView™ Built-in Line Doubler
Natural Color Matrix
Digital-Expanded Zoom
2 live Picture-in-Picture (PiP)
Remote Control with Laser Pointer
Specifications
Resolution XGA (1024 x 768)
Brightness 1100 ANSI Lumens
Dimension 9.5 x 3.1 x 11.5"
Display Device 0.9" x 3 Polysilicon LCD panel with micro-lens array
Data Signals PCs, Macintosh® computers, workstations up to 1280 x 1024
No. of Colors 16,770,000
Contrast Ratio 250:1
Lamp 150-watt UHP lamp; with 2000 hours lamp life (user changeable)
Lens F1.7 (100":3.6mm)
Input RGB1; mini D-sub 15 pin x 1 Video; RCA x 1 + SVHS x 1 Audio; RCA x 2 (stereo)
Output RGB; mini D-sub 15 pin (Monitor)
H_sync_range 15-92 kHz
V_sync_range 50 - 85 Hz
Built in Audio 1W mono
Image Size 40-300" diagonal
Throw Distance 55" - 548"
Retailed for $6000US dollars. Payed over $3300 US. Priced at $3000CAN. I will also include a high quality screen. It is a Dalite 52"x92" (106" diagonal) High Contrast DaMat grey screen. The screen alone sells for $450US+. The screen is basically unused. You can get into front projection for the same price as a good big screen tv. Will sell quickly! Please send me a PM with questions/queries or email me.
Features
1100 ANSI Lumens
Specifications
