Chuck Frady
- Oct 14, 1998
I sold my Sony STR-DA4ES a couple of months ago here and purchased this receiver brand new in the box at Magnolia Hi Fi and Video in Seattle on June 18th.
I will forward on the receipt to the new owner showing when and where it was bought and for warranty purposes.
Asking $650 shipped.
I can take pics and email them to you if you would like some.
Paypal is preferred.
Please send all inquiries etc to my email if you can. Don't use IM since I am not on the board all the time.
I have been a member here since 1998 and have bought and sold many an item..so be comforted that in light of some of the recent scams on this forum, I am not one of those guys and you can be assured you will get a beauty of a receiver.
Specs are as follows:
Versatility, power, and convenience: to align its output with your speakers, the VSX-45TX's Auto-MCCAC (Multi-Channel Acoustic Calibration Circuit) automatically evaluates a room's environment and calibrates your system's output accordingly, for easy, accurate setup. It also features THX Select certification, 100 watts of power into each of 7 channels, and exceptional surround decoding, including DTS® Discrete 6.1 and NEO:6 Music and Movie, plus Dolby® Digital EX. High-end D-A/A-D conversion and a Hi-Bit Audio Scaler-which converts digital sources to 96kHz/24-bit resolution-deliver pure, full audio reproduction. The ruggedly built VSX-45TX includes an illuminated Smart LCD remote and the Elite two-year warranty. M.S.R.P. $1,400.
Power:
THX Select Certification /Air Studios Sound Tuning
Advanced Direct Energy MOS FET
Wide Band Frequency Response (5Hz -100kHz)
100 watts x 2 Stereo
100 Watts x 7 Multi-Channel
Decoding:
Dual Motorola DSP Engine
DTS-ES Discrete 6.1
DTS NEO 6: Music & Movie
DTS 96/24
Dolby Digital-EX
Dolby Pro Logic II Music & Movie
Processing:
Hi-Bit Audio Scaler converts digital sources to 96kHz/24-Bit Resolution
96kHz/24-Bit A/D Conversion (2 Ch.)
192kHz/24-Bit DAC
Auto MCACC (Multi-Channel Acoustic Calibration)
Manual EQ Adjust (5-band x 7)
THX Select Post Processing
7-D Theater
7 Channel Stereo
6 Cinema Modes
6 Concert Modes
Digital Noise Reduction
Midnight Mode
Multi-Channel Multi-Band EQ
Loudness
Connectivity:
RS-232
USB - Rear
Multi-Channel Input- All
Multi-Channel Outputs - All
Digital Input - 5 (2 coaxial, 3 optical w/front)
Digital Output - 2 optical
6 Audio / 5 A/V Inputs (including Tuner)
2 Audio / 2 A/V / 1 Video Output
Phono Input
S-Video - 5 In / 2 Out
Component Video In/Out
Front A/V Inputs
Banana Speaker Terminals
AC Outlet
Convenience:
Function Rename
30 Tuner Preset
Command Macro
MR/MS w/ Front Panel Control
Surround Back to MR/MS Amplifier Re-Configuration
12v Trigger
Illuminated Smart LCD Remote
DVD, DSS, DTV, Multi-CD Control
Construction:
Extra Large Extruded Aluminum Heat Sinks
CAD Design 3-D Space Frame Construction
Frame Reinforced Isolated Chamber
Double Layered Transformer Stabilizer
Aluminum Front Panel
Aluminum Volume & Multi-Jog Dial
Power:
Decoding:
DTS-ES Discrete 6.1
DTS 96/24
Dolby Digital-EX
Processing:
192kHz/24-Bit DAC
7-D Theater
7 Channel Stereo
6 Cinema Modes
6 Concert Modes
Midnight Mode
Loudness
Connectivity:
RS-232
USB - Rear
Phono Input
Front A/V Inputs
AC Outlet
Convenience:
Function Rename
30 Tuner Preset
Command Macro
12v Trigger
Construction:
