charles_w
- May 11, 2001
I'm selling my Home theater equipment starting with the Amplifiers.I have an Acurus A200x5 5 channel home theater amp for $800.00 Shipped to the lower 48
POWER OUTPUT 8: 200
POWER OUTPUT 4: 300
FREQUENCY RESPONSE: 20Hz-20kHz
THD: 0.06%
SN RATIO: 110 dB
INPUT SENSITIVITY: 1.1 volts for full output
INPUT IMPEDANCE: 20kOhms
HEIGHT: 6.75" (17.15 cm)
WIDTH: 17" (43.18 cm)
DEPTH: 14" (35.56 cm)
WEIGHT: 50 lbs. (22.68 kg
And the Acurus A125x5 5 channel home theater amp for $650.00
-125 Watts into 8 ohms & 150 Watts into 4 ohms
-20Hz to 20kHz Frequency Response
-ab Power Class
-110 db SN Ratio
-0.06 Percent THD
-Input Sensitivity - 1.1 volts for full output
-Input Impedance - 20K ohms
-42 lbs
-17" x 14" x 6.75"
Both are in excellent condition and will be shipped in original box and packaging.
POWER OUTPUT 8: 200
POWER OUTPUT 4: 300
THD: 0.06%
SN RATIO: 110 dB
-ab Power Class
-110 db SN Ratio
-0.06 Percent THD
-42 lbs
-17" x 14" x 6.75"
