DVDO VP50 Pro Processor - New in Sealed Box Retail $3500 HTF $ 2299 (1 Viewer)
Gregg Loewen
Founder, Professional Video Alliance
Insider
New England
Gregg Loewen
hi guys
I have one of these units left over from the Power Buy and do not want it collecting dust. It is new in the box. I am an authorized DVDO seller so the buyer will have the full warranty.
This is the 50Pro with a retail price of $3499 not the the vp50 that has a retail price of $3000.
My price is $2299 then add $15 to ship in the US. This is for 1 processor that is an overstock item and I need to get it out of my lab.
Please email me at [email protected] or call 201 232 3380 to purchase.
thanks
Gregg
The DVDO iScan VP50PRO is the world's first video processor to receive the THX certification. The VP50PRO also is the first video processor to use HDMI 1.3 receiver/transmitter chips, which allow users to connect other HDMI-compliant 1.3 devices that support high-resolution audio formats and 12-bit Deep Color, available on some newer sources like HD-DVD, Blu-ray, and the Sony PS3.
DVDO iScan VP50PRO Scaler Summary:
4 HDMI 1.3 Inputs which process up to 1080p-24/25/50/60 input signals and 1 HDMI 1.3 output
Flexible Input Aspect Ratio Control (4:3, Letterbox, 4:3 Stretch, 16:9 and 10-User Defined Presets)
Support for Anamorphic lens configurations including 2.35:1 Constant Image Height projection systems
Full-frame Timebase Correction
The DVDO iScan VP50PRO is a high-definition video processor and A/V hub that converts standard definition, high definition ( including 1080p ) and PC signals from your DVD player, HD-DVD player, Blu-ray Disc player, HD DVR, game console or PC to any output resolution between VGA and 1080p, including popular HDTV resolutions such as 720p and 1080i.
DVDO iScan VP50PRO Key Features:
Mosquito Noise Reduction reduces random noise which appears along the edges of compressed images
Fine Detail Enhancement to extract fine detail in low-resolution or compressed sources
Edge Enhancement to sharpen edges without adding any ringing
HDMI 1.3 Input/Output
12V triggers
ISFccc Day/Night Modes
DVDO iScan VP50PRO Inputs and Outputs:
12 Video Inputs Available:
2 x Composite (NTSC/PAL/SECAM)
2 x S-Video (NTSC/PAL/SECAM)
2 x Component (Y-Pb-Pr or RGB/S) processes 480i/p-60, 576i/p-50, 720p-50/60, 1080i-50/60
1 x RGB-HV/Component (BNC-style connectors) processes 480p-60, 576p-50, 720p-50/60, 1080i-50/60, VGA-SXGA@60Hz
4 x HDMI 1.3 (RGB or Y-Cb-Cr) processes 480i/p-60, 576i/p-50, 720p-50/60, 1080i-24/25/50/60 inputs, 1080p-50/60, VGA-SXGA@60Hz
1 x SD-SDI (Serial Digital Interface) Optional processes 480i-60, 576i-50, 720p-60p, 1080i-50/60, 1080p-24/25/30
9 Audio Inputs
4 x HDMI 1.3
2 x Assignable Coaxial Digital
2 x Assignable Optical Digital
1 x Assignable Analog Pair (L/R)
DVDO iScan VP50PRO Outputs:
Video Outputs:
1 Digital Audio/Video Output using HDMI (High Definition Multimedia Interface) connector configurable for RGB (4:4:4) or Y-Pb-Pr (4:4:4 or 4:2:2) also carries digital audio
1 Analog using BNC-style connectors configurable for Y-Pb-Pr, RGB-HV, RGB/S, or RGB
2 Digital Audio Outputs:
One Coaxial Digital
One Optical Digital
DVDO iScan VP50PRO Package contains:
DVDO iScan VP50 pro
Universal AC mains input: 100 - 240V @ 50 - 60 Hz
Remote Control
User Instructions
What does the DVDO iScan VP50pro has that the VP50 doesn't have?
Edge Enhancement
HDMI 1.3 Enabled
ISF ccc Certification
2 programmable 12v triggers
Upgradeable to SD/HD-SDI Dual Input Module
Panamorph Mode 1 and Mode 1 compatible
Warranty: The DVDO iScan VP50-pro comes with one year parts and labor manufacturers warranty.
Edwin-S
Can it upscale a 720p signal via HDMI to 1080i/p and then pass it over the component outputs? If it can, would you ship to Canada?
Gregg Loewen
Insider
New England
Gregg Loewen
hi
yes you can go from 720p to 1080p (or 1080i), no you can not switch to component as that is a copyright violation (on encrypted digital signals).
Yes I can ship to Canada.
Edwin-S
Hi. Thanks for the response. I sort of suspected it couldn't do what I asked about, but I thought I'd check anyway. Still that is a steal of a deal for that unit. I'd snap it up if I could get any benefit out of it right now, but I would have to upgrade the old video chain to get any real use out of it. Guess I'm going to have to eventually bite the bullet and decide on a video upgrade path. Thanks again.
Amended: Would this unit help in alleviating the HF filtering that plagues the Toshiba HX81 series of RP sets? See. I'm deperately trying to come up with rationalizations to buy this unit since I think that it is a pretty good deal for an outboard video processor. :)
Gregg Loewen
Insider
New England
Gregg Loewen
hi Edwin
I just saw your question. Absolutely yes.
please let me know ASAP if interested...i am currently dealing with 2 other inquiries but no firm yes on my last unit.
thanks
mycuu
