Dtronics 2x1 HDTV DVI Switcher DS-21R w/Remote As New! (1 Viewer)
Wayne Reibold
Like new condition Dtronics DS-21R 2x1 HDTV DVI switcher 480p/720p/1080i two DVI source in, one DVI signal out HDCP compliant. Includes switcher, power source, original box, original remote and original manual (as in everything it comes with new) plus purchase receipt.
$160 includes the DVI Switcher shipped to you for free via Fedex Home Delivery with a declared value of $160. Please check feedback about me on eBay under WynsWrld98 for confidence in buying. PayPal preferred but money order/cashiers check are fine too.
I've used the switcher with an HDTV DirecTivo HR10-250, Bravo D1 DVD player and Sony VPL-HS10 projector and it has worked flawlessly. I was also able to use its remote codes with my Pronto remote control. I'm selling because I've gone to an all HDMI setup so I no longer have a need to switch DVI sources.
The DVI cables feed out of the back of the unit which makes the unit look nice in an a/v cabinet (vs. an ugly design such as the Gefen DVI switcher which has cables coming out the front and is a horrible bright blue vs. the nice black of the Dtronics). I previously had a Gefen 2x1 DVI switcher and had nothing but problems with it and had to return it. The Dtronics was a pleasant surprise after the Gefen unit.
For further details: http://www.dtronicsinc.com/product/ds-21r.html and http://www.pacificcable.com/Picture_...aName=DS%2D21R
IMPORTANT DIFFERENCE BETWEEN DVI SELECTORS AND DVI SWITCHES
The differences between a DVI Selector and a DVI Switch are important to note:
1) A selector bridges different sources to a single outlet without amplification of the signal.
2) A switch delivers the highest quality picture preserving the native resolutions of the video sources without any signal loss. Several chipsets are required to detect and boost the signals to a uniform and reliable output. This requires constant power supply.
A way to tell if you are purchasing a selector or a switch is whether power supply is required. DVI switches require a power supply while selectors have an optional power supply that doesn‘t power chipsets. DVI switches also cannot pass analog signals because the existing chipsets can not analyse the analog signals like digital signals which is necessary for reliable amplification.
MORE SPECIFICS ON DVI SWITCHES
1. High Quality Picture - No Signal Loss and Digital Noise Free
Our switchers are built to deliver the highest quality picture preserving the native resolutions of the video sources without any signal loss. When going through multiple connections(adapters, switches, etc), 1s and 0s of the digital information gets lost or deteriorated and this would appear as a blinking screen or thin lines. In order to preserve the original digital information, the signal needs to be boosted. Our switch amplifies the signals so that the signals are strong enough to have minimal loss in order to preserve its original digital signal.
2. Signal Amplification for signal reliability and long length signal transmission. Our 5V power adapter supplies adequate power to amplify the video signals from different video sources. This is necessary as the overall length from the video source to the displays is longer when using the switches(distance from the video source to the switch + distance from the switch to the display). In most cases, the overall distance that the DVI signal will need to travel is over 10ft. Due to the nature of DVI signals, amplification is necessary to warrant the video quality and reliability. (Without amplification, there may be occasional blackouts or blinking effects) With this amplification feature, your video display can be extended upto 2300ft using our fiber optical DVI cables.
3. Compact and Practical Design
Our switchers have all of the DVI ports, power supply jack and RS232 port in the back of the unit allowing it be mounted on any racks or with any other components. In the front, there will be a remote control sensor, selector switch, RS232 LED indicators and channel indicators.
4. Remote Control Unit with Discrete Channel selections
Remote Control Units with discrete channel selection feature is included in all our switches. The channel buttons on the remote control unit will allow you to change video sources easily and quickly.
5. RS232 Control
Our switches also feature RS232 Control. Our switches are capable of being controlled by a remote computer. This is extremely helpful for many applications where you need to automatically switch the video inputs. Example: If you connect a PC to our switcher, you can program it to automatically switch the sources. If you want to display input 1 for 1 hour and then switch to input 2, you can do this with the PC. The RS232 LED indicators in the front will allow you to check the communication between the PC and the switch. Most other products require additional control box for this function.
Be sure you understand these differences. Comparable DVI switches from other companies to our DVI switches are being sold for between $799 - $900 for the four position.
Description
The DS-21R DVI Switch allows two different digital video sources to share one video display. Our unique switch allows easy switching between two different digital video sources with remote control unit or manual switching button. Perfect for home theater systems. No more hassles of manually plugging in different DVI connectors to view two different video sources. (e.g., DVD and Satellite receiver).
Features:
Easy switching between two digital video signals (e.g., DVD and Satellite receiver) using remote control or the switch button on the switch.
Remote control suports discreet codes.
Intuitive LED display of video source channels.
Supports high resolution UXGA (1600 X 1200 at up to 85Hz) (1920 X 1080 at up to 70Hz) - The only switch in the market to support this resolution.
Low cost solution for home theater integration.
Plug-and-play. No software installation. Installs in minutes.
Application:
Home theaters with two different digital video sources and one display.
Monitoring systems.
Use of two computers with one monitor. Ideal for designers and architects. A great space saver.
Technical Details:
Frequency bandwidth: 1.65 Gbps (Single Link)
Supporting Graphic Resolution: UXGA (1600 X 1200 at up to 85Hz) (1920 X 1080 at up to 70Hz)
Inputs: Dual DVI-D Female ports
Output: DVI-D Female port.
Power supply: DC 5V, 2A Adapter included.
Dimensions (W X D X H): 6.7 X 4.75 X 1.2 Inches.
Weight: 1.35 lbs.
Infrared Remote Control Included
HDCP (High-bandwidth Digital Content Protection) Compliant.
RS232 Port Information
Control computer's RS232 pin# 2 is connected to our DVI switch's pin#3
Control computer's RS232 pin# 3 is connected to our DVI switch's pin#2
The control protocols are as follows:
Channel 1 request is ascii code "@001*" and the response back to the computer is "!"
Channel 2 request is ascii code "@002*" and the response back to the computer is "!"
Channel 3 request is ascii code "@003*" and the response back to the computer is "!"
Channel 4 request is ascii code "@004*" and the response back to the computer is "!"
Hex Codes for Pronto TSU3000 Remote:
Hex codes for INPUT1 :
0000 006D 0018 0000 002F 0045 0018 005C 0030 005B 002F 0044 0018 005C
0030 082B 002F 0044 0018 005B 0030 005B 002F 0044 0018 005B 0030 082B
002F 0044 0018 005B 0030 005B 002F 0044 0018 005B 0030 082B 002F 0044
0018 005C 0030 005B 002F 0044 0018 005C 0030 0045
Hex codes for INPUT2 :
0000 006D 0018 0000 002F 0045 0018 0045 0046 005B 002F 0044 0018 0045
0046 082B 002F 0044 0018 0045 0046 005C 002F 0044 0018 0045 0046 082B
002F 0044 0018 0045 0046 005B 002F 0044 0018 0045 0046 082B 002F 0044
0018 0045 0046 005B 002F 0044 0018 0045 0046 0045
Wayne Reibold
bump! This is about $70 less than any price I've seen on this and it's in perfect condition and includes everything as if new.
mycuu
