I have the ver 1/6 firmware update installed. A side question: I'm rather new to BD and bought the BD30 a couple of months ago. I have a few discs that list "PCM 5.1 uncompressed" and I'm starting to see more of this now. However, I've noted that to access that I actually have to stop the player or do this prior to loading such a disc and then go into Setup. Do other BluRay players require this procedure?
My primary questions are specifically, what do I change here? I went into "Digital Audio Output" and see (4) codecs listed: DD, DD+/TrueHD, DTS and DTS-HD. However, each has a choice "Bitstream" and "PCM." As the cover doesn't specify anything than "PCM uncompressed," which of these do I change to PCM - ALL of them, just Dolby Digital, etc.? I also assume that BD Video Secondary Audio is left at OFF. Is this enabled only when listening to video/audio commentaries? Working a DVD player was child's play next to this equipment.
This is rather confusing. It's bad enough we have to stop the disc and go into the player's menu to access this but when getting there the resolution is not clear. The manual only muddies the issue for me.
Finally, I see another choice in the upper menu with Digital Audio Output and that is PCM Down Conversion. I presume this is left at OFF for those with full 5.1 (or better) audio systems, which I do have.
FYI: I have this hooked to an Onkyo TX-SR805 receiver via HDMI.
Someone please clarify this mess for me! :frowning:
