Another thought, I did have to switch the audio output on my Oppo from Auto to something specific. I found immersive soundtracks often played in 7.1 until I made that change.
When I hooked it up, I replaced all of my HDMI cables with Monoprice Certified cables.That doesn't sound right. I've never had that happen, except occasionally when I play an MKV file that has a Atmos/DTS:X soundtrack. I have updated all my hdmi cables to certified Monoprice models.
It's having trouble locking onto the audio, which I've found has gotten more common as the soundtrack options get more complicated. Still, it shouldn't do that. Mine don't, though they can take a few seconds to lock on and un-mute the audio. I have noticed that the angle of the remote seems a little narrow, though it's not really an issue in my setups. In fact, I can often bounce the remote off the opposite wall, with the Harmonys anyway, which seem to have a stronger output.When I hooked it up, I replaced all of my HDMI cables with Monoprice Certified cables.
@JohnRice All of my audio dropout issues have stopped as well as the Marantz response to my Harmony remote. I upgraded my remote the other day to another Elite and those prior issues have cleared up since then.It's having trouble locking onto the audio, which I've found has gotten more common as the soundtrack options get more complicated. Still, it shouldn't do that. Mine don't, though they can take a few seconds to lock on and un-mute the audio. I have noticed that the angle of the remote seems a little narrow, though it's not really an issue in my setups. In fact, I can often bounce the remote off the opposite wall, with the Harmonys anyway, which seem to have a stronger output.
That's good to hear. Something was definitely wrong. As far as displaying audio info, I use the OSD, which is the "Display" button on the remote, as I recall. You might have to reassign a button on your Elite. I assigned it to the "Info" button for the device, and put a soft button at the top of every activity. It shows a lot of info, including input channels, output channels, input audio format, any additional processing and some more stuff. I don't remember if it shows video info, but I have video processing turned off on both my units.@JohnRice All of my audio dropout issues have stopped as well as the Marantz response to my Harmony remote. I upgraded my remote the other day to another Elite and those prior issues have cleared up since then.
I do have one question, what is the best way to display audio and video information that the Marantz is outputting? I have every device operating through the 6013 to the OLED.
I guess I vaguely recall coming across those menus when I got the AV7703. I was surprised to see such extensive info. Since then, I've just used the regular OSD to verify the incoming channels and format. Of course, that system doesn't have any 4K, so further info isn't much of a factor.I found a way to display audio and video information on the 6013 by accessing the Setup Menu then the following prompts
Press General
Press Information
Press Audio
Press Video
Press HDMI Signal Info.
Nope!I'm always curious if you're bothered by the small porthole display. That tends to be the main complaint with Marantz.
