Octavio
- Dec 23, 2003
I'm planning to upgrade my DVD player and I'm considering new Denon models DVD 1910 or DVD 2910 (will come out in September) and I have a couple of questions.
DVD 1910 manual is on Denon website, DVD 2910 manual can also be found in Denon website, but there is not a link to get it, so this is the address for each model:
http://www.usa.denon.com/catalog/pdfs/DVD1910%20DFU.pdf
http://www.usa.denon.com/catalog/pdfs/DVD2910%20DFU.pdf
Now my questions:
1. If I use the player DVI output to my Sony KV-30XBR910 DVI input, I understand that the video signal never gets analog so I'm not using any video DACs, right? If so, should I get exactly the same video quality using DVD-1910 model ($270) than DVD-2910 model ($730) no matter if they have different Faroudja DAC's?
In other words, and only from the video perspective, I should prefer 1910 model because I wouldn´t get anything else from 2910 model and I would save $460.
2. Now, let´s go to the audio section.
I'm planning to connect the DVD player to my Denon AVR-3805 Receiver, which has enough Burr Brown DAC´s. Then, as long as I use a digital connection between them, the AVR-3805 will decode my CD's, right? So, to listen to regular CD´s, the decision should also be the DVD-1910 model and save the $460 difference, right?
Let's say that I would like to have the chance to listen to DVD Audio and SACD discs (not available in DVD-1910 model). One option is to get Denon DVD 2910 and pay $460 more, and other option would be to buy a five disc "universal" changer (DVD/CD/SACD/DVD-Audio) like Toshiba SD-6915 for $180 (in addition to DVD-1910) and listen to DVD's and regular CD's using AVR-3805 Burr Brown decoders, watching video using DVD-1910 DVI output and listening to high resolution DVD Audio/SACD using the multichannel analog output of Toshiba SD-6915 going to external decoder input of AVR-3805. This last option would give me disc changing capability (6 discs in total) and also a saving of $280, compared to option 1, but I'm not sure what I would be giving up.
Thanks for your advice,
Octavio
Now my questions:
Octavio
