Kelly
Grip
- Jul 24, 2001
I posed this question to Def Tech. Now tell me what you think. I am thinking of buying Def Tech 2006TL / 2300 / BP2X speaker system. I already have an SVS sub. Should I still buy the "power tower" 2006TL with their built in sub, or buy something else like the BP10? Def Tech's reponse was "the BP10Bs are a bit better than the BP2006TLs. The 6.5" drivers used in the BP10Bs sound a bit richer and fuller than the 4.5" drivers used in the BP2006TLs". What do you think? I have not auditioned the BP10 so I need to obviously do that before deciding. The BP10 is about $100/ea. cheaper (I believe) but the 2006TL would probably be considered a better match across the front with the powered center channel and it's internal sub. Please provide input!
