MichaelPe
- Feb 22, 1999
http://www.d-skin.com/
Basically, it's a thin protective film that you put on the data side of a CD (or DVD). It helps prevent scratches, and it stays on while you play the disc (apparently, it's removable too). However, I'm very skeptical about it, and I was wondering if anyone had used these?
I'm sure that this would be useful for video-rental stores. Although, I'm guessing this wouldn't work too well for double-sided discs...
