Debbie K
Grip
- Oct 25, 2002
Well, as the title suggests, I am experiencing a strange clicking/crackling sound occasionally from my right rear surround and am not sure if it is the receiver/speaker/or source. Any ideas would be most appreciated!
I have a new Denon 1803 and JBL speakers, the speaker in question is the N24II. I am using monster cable speaker wire and AR Banana Plugs if that makes a difference. I checked the connections and all seems well. (?)
The reason I am not sure if it is the source is because I have only noticed this when watching regular cable TV using PLII cinema mode, not when watching a DVD. It is not very loud, but sometimes I hear a short crackling/static sound like you were moving the wires around or something and causing a slight short. Same sort of sound. But I am not moving anything.
If this is a common thing while watching regular TV I will just get used to it, but if perhaps there is a problem with my receiver, I need to exchange it or return it as I am still within the 30 day return period.
Thanks for any ideas! Debbie
