World Wide Stereo
Can I change the display color of my Elite VSX-54tx? (1 Viewer)
Vincent_S
Browsing through Pioneers website and looking at the picture they have posted it looks like the display is blue. Mine is an amber color. Can this be changed to blue? If you go back and forth from the 52tx and the 54tx you can see the difference. I looked at my owners manual but couldn't find anything on it.
David Judah
No, you as an end user can't--I doubt it's even possible. You could try putting a dark blue transparent piece of plastic over the display, like the blue filters used for setting color and tint with Avia or DVE. I don't know if that would do it, but you could try it, if it's a big deal to you.
DJ
ciuycjsgfvbn
SVS Outlet Sale
