Shene
I have both a 5 channel Anthem amplifier and an Anthem 15.4 processor/preamp on order. I also have a pair of subwoofers at the same end of the room as my Video/theater equipment cabinet. These 7 lines could be encased in one of those wire wraps at least from the processor to the first subwoofer and Anthem inputs that act like a Chinese finger puzzle often used for a speaker wire to supposedly look better. I am only trying to clean up my cables, not decorate them. I would likely put all the wires through before installing the Neutrik connectors on the second end. One line going to the input of the left subwoofer would just extend on its own to the opposite corner for the second sub. I do not think making the bundle rather than having all of the cables loose should cause any wire to wire fields that would make a less than ideal transmission. Any opinions on if this is not the best way to go? Once in the cable wrap they would not be removable except if one connector end would be removed for each cable to be removed.
