Justin Ward
- Jun 6, 2002
I am pretty comfortable with working on the inside of a PC so I think I will build my next PC. I want something to do school work on but I also want it to play games well and to be useful for video/audio capturing/recording.
I want to spend under $2000 Canadian(this is set in stone). I would also prefer to buy from a Canadian dealer.
Here are some of the components I was considering:
Video: GeForce 4 or ATi Radeon(which model should I get if I want good game performance and S-video in and out).
Audio: I am pretty much settled on the Audigy 2 but I am not sure if the upgrade to Platinum is worth the extra $$.
Processer: I was thinking of going AMD to save money but if it is not a good idea I could go with a slower P4.
I have another question as well. If I got the Audigy 2 and used my PC as the DVD player could I get 6.1 even though my reciever is only 5.1? I think I could do this by hooking up an extra amp to the cards preouts to do the rear center and send the rest of the channels to the recievers 5.1 input.
Anyway, I probably won't be able to afford this for a couple of months but I wanted to get an idea what to look for.
Justin Ward
Justin Ward
