HubbaBubbaKid
- Jun 26, 2019
- Frankie
Hey guys and gals , i ordered the Bionic Woman BD —(SD on Blu Ray) from Turbine and i cant get it to play the episodes. it will get to the menu but once you hit play on an episode it pauses then highlights the next episode. every disc does this. i was told this and the SMDM set was region free. i ordered both from Amazon germany and the SMDM set plays great but this is doing what i described. i immediately thought it was bc it was region locked but everything i‘ve researched about region locked sets say that you can’t play the disc at all, there will be a warning saying its incompatible , is that not correct? i don’t have a region free player so i can’t test it to see if that’s the problem. whats weird is that both sets say region B on them but the Bionic Woman also says PAL , is it a PAL compatibility issue? i know that sometimes some companies have descriptions on the sets that don’t align with what the actual product is -like the SMDM set and i just wanted to make sure its not a manufacturers defect before i get a region free player. i emailed Turbine and am waiting on a response. any help would be greatly appreciated. —frankie
