Aaron Smithski
- Jan 18, 2002
As you can see, I too have been visiting uBid! I was able to get 5 PA-2000's for $171 shipped. The plan was to run all 5 of them in my theater with a Denon 3802. The 3 front speakers are a/d/s MV20/u's (which are bi-ampable) and I was going to use one PA-2000 per front speaker. This would send 100 watts to the 2-8" woofers and 100 watts to an MTM array of 2-1.5" dome mids and a 1" dome tweeter. The 2 rear pairs are a/d/s bipole/dipole speakers, with each pair getting their own PA-2000 @ 100 watts per channel.
The dilemma arises when I was informed by a friend who has a couple of extra Parasound HCA-855A's (also from uBid, the all-time great source of amplifier discounts!) that he would let me have 2 of his 855A's for his cost of $320 each shipped!
All of the a/d/s speakers are rated 4 ohms. I tried to measure the impedance of the MV20/u's with the jumper bars removed and measured 5.2 static ohms for the 8" woofers together but cannot get a reading for some reason on the high-frequency drivers. The surrounds measured 7.1 ohms when hooked up to the ohm meter. I know that the ohm loads change with music but I guess I am confused as to how this affects the static rating.
I remember that a few of you have experience with both amplifiers and I wanted to know how the outputs of these two compared in real life. The 5 HK's are rated @ 100 watts x 10 channels into 8 ohms and the 2 Parasounds would be 85 watts x 10 into 8 ohms or 125 watts x 10 into 4 ohms. Can the HK drive 2 channels bridged at 4 ohms? I understand that most HK stuff is underrated power wise but would really like to know if it would/could put out more than the 100 watt per channel 8 ohm rating when driving two 4 ohm channels.
The 2 Parasounds require more input power when you look at manufacturer ratings compared to 5 of the HK's. The 2 855A's need 1500 watts and the HK's need a total of 1300 watts. It would seem logical that the Parasounds would output more since they draw more in but I think that there may be something to be said for having 5 separate amp chassis to spread out the distribution of power.
It would be easier to only have to mount and connect 2 amps instead of 5 but the 5 HK's sure would look neat!
Any help you guys can lend me is appreciated!
Aaron
Aaron
