Scott L
- Feb 29, 2000
Just installed a Zalman flower and BOY what a difference! The comp now makes about 1/3 the noise my Xbox does, the loudest thing being a 40gig WD harddrive. Next up, a HD enclosure!
Case is a D-Vine 4 series which looks like it keeps noise out but it doesn't.. sound seeps under the front air inlet on the bottom and even through the 5.25" bay door.
Stock HSF with noiseless heatpipe VGA cooler and a small 80mm custom fan mount.
Zalman ships their noiseless fans with a little adapter which is just a resistor to limit power intake to the fan, reducing noise and RPMs dramatically. I just couldn't get enough airflow with an 80mm and luckiy found that a 92mm fits and is whisper quiet with the resistor spinning at 1600rpm. Placement here needed a small angle iron, this area is great because it also keeps the HD's relatively cool. The 120gb Maxtor heats up very fast and is almost too hot to touch at times.
The pure copper version of this flower is heeeavy, but that's good since copper is denser and dissapates heat better than aluminum. (note the 92mm fan)
Used the paste that came with it to grease up the p2.4b, the clips were relatively easy to snap into place.
Used the supplied fan speed controller to keep the fan hovering around 1500rpms, just about where I couldn't hear it. Although people say they got hotter temperatures with this quiet setup I got the opposite. I get cooler and more stable temperatures when playing games & DV encoding than the stock Intel HSF. (check out the htpics dir for more pics)
Cost:
Zalman Copper Flower kit: $36 shipped from BBC.
Zalman Heatpipe cooler: $24 shipped refurb from Newegg
Zalman ZM-F2 noiseless 92mm fan: $14 shipped
Total = $74
A little more than I'd like but worth it in the end, especially when your computer's in the theater.
Cost:
Total = $74
