- Feb 8, 1999
- Robert Harris
Another very important release from Twilight Time, Martin Ritt's take on William Faulkner's The Long, Hot Summer, with a screenplay by Irving Ravetch and Harriet Frank, Jr., a married screenwriting team, that seems to be able to create magic in their words.
Ms Frank recently turned 100.
This is also, another production with extraordinary casting.
Paul Newman and Joanne Woodard in the leads (they married shortly thereafter), with great support from Anthony Franciosa, Orson Welles (in a wonderfully over-the-top performance, Lee Remick and Angela Lansbury.
With major location filming in Louisiana, the film veritably drips with summer heat and humidity.
The master supplied to Twilight Time by Fox, appears (at least to me) to come from an element with a bit of fade. Flesh tones appear a bit too yellow than the norm, and one will occasionally find blue highlights in darker areas. Note the furniture in the bedroom, early in the film.
The fade doesn't impede the overall image quality, and as "the play's the thing," the eye gets used to it. The audio seemed a bit odd at points, with the sound not quite tracking the position of the actors, but it may have always been like that.
If you've not experienced Long, Hot Summer, this is your chance to get one of the 3,000 examples, as issued.
Image - 4
Audio - 4.5
4k Up-rez - 4.75
Pass / Fail - Pass
Recommended
RAH
Image - 4
Audio - 4.5
4k Up-rez - 4.75
Pass / Fail - Pass
Recommended
RAH
