- Feb 8, 1999
- Robert Harris
Of the dozen or so variants of George Miller's Mad Max Fury Road, that Warner Bros. will be releasing over the next year or so, their new 4k uprez is a most interesting creature.
Resolution is superb.
HDR makes a huge difference. In fact, It's probably an equally dynamic version to the black & white we expect to see.
Viscerally, it's a totally different film from either of the current Blu-releases.
Color, densities, black levels within HDR are stunning. Audio is what it has been, which is superb - and Huge.
That's the good news.
The bad news is that to be perfectly honest, I'm not exactly certain what it's supposed to look like. While I like the way that I have it set up -- this after realizing that the Samsung defaults your projector or panel to virgin territory, sans calibration, the first time the viewing device sees a new 2160 signal, and then plugging all of my calibrations back into the projector anew.
Are those calibrations correct? Not sure. Are they probably close? Decent chance.
I still don't know that I have it right. I'm just happy with what I'm seeing. Which is not what this is all about.
While the 4k uprez is gorgeous, there are certain attributes, which I question, as they seem to possibly show, and I say possibly, as I've not seen the original data files, effects that may not play properly at 4k -- mostly the highlights on flames. They do look neat, and in your face. Everything else seems to track nicely.
All of that said, if you read my "First Impressions" piece regarding 4k, I'm recommending to all but the staunchest home theater fans, to wait for probably 3-6 months, if you're planning to play anything except new 4k discs on your Samsung.
The player has not been properly tested, and is not ready for release.
If you don't mind going through continuous firmware upgrades, and the absolutelely shitty Samsung technical support, as they solve problems that should have been remedied before release, go for it. But I warned you.
A great disc, played on a system not ready for public consumption.
Image - 5
Audio - 5
4k - 5
Pass / Fail - Pass
Very Highly Recommended
RAH
Image - 5
Audio - 5
4k - 5
Pass / Fail - Pass
RAH
