World Wide Stereo
12 volt Trigger Out - Uses? (1 Viewer)
Neil White
I'm waiting for my 3803 to be delivered. When I get it it will be time for a rewire of a number of things in my HT. One of the things I want to address is cooling. My current Onkyo Integra 838 actually has a volume/temp-activated fan but it never kicks-in early enough to keep things as cool as I would like. I don't think the Denon even has a fan but regardless, I want to install a fan in my rack that is triggered by the receiver. Can I just connect a 12 volt fan (like 5 bucks from PArts Express) to the 12V trigger on the 3803? Or, is that trigger just some kind of pulse for triggering relays?
BTW - did a search but the results were overwhelming.
N
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
The trigger is similar to what you find on car audio head units: It's designed to switch on amplifiers, not carry a load.
Wayne A. Pflughaupt
Neil White
Okay, thanks Wayne.
So the next question is, how do I go about doing what I want to do with this fan business? Find one that runs at 120V I guess and run that off the receiver?
N
Massimo N
You can always use the switched outlet on the back of your receiver and use a 12v DC Adaptor to power the fan.
LewB
You can buy one of these and use it to power 120V stuff if you don't have or run out of switched outlets. I used a Radio Shack cable that has a mini-plug on one end and spade connectors on the other. I clipped off the spade lugs and was in business. I use this set-up to power on/off my sub along with a powered FM antenna from my receiver.
FFMichael
SVS Outlet Sale
