Ville Varonen
- Sep 2, 2014
Hello!
Can you help me identify this wierd problem. Is it in green lcd panel? I already try to locate problem to polarizators. They are not causing it. I also try to clean proctor so well what I can. With vacom cleaner and canned air. I can try more if you think its could help.
Projector is 5500h old. And 2. lamp is quite old too 3500h. Is it possible the bulb cause this?
Thank you so much!
http://www.taikurikari.fi/kuvat/panasonicproblem.jpg
Thank you so much!
