Problems learning Delphi remote codes (1 Viewer)
Tom_A
Looking for experiences in learning the Delphi's remote codes into an universal remote. I was able to get the codes learned into my Marantz RC2000 II, but I can't get the Delphi unit to accept consecutive commands from the same button. For example, I can tune to channel 123 using the Marantz, but not 112 as the unit will not take the second 1. Also can't use the channel up (or down) button two consecutive times. Taught the remote that came with my Denon AVR-3200 the Delphi commands, same thing happened. Never had this happen before.
If anyone has any ideas, I'd appreciate it.
Tom
Gary Silverman
Tom, For whatever it's worth, I have a Pronto and it WAS able to learn all the codes. I still want to have separate on and off commands rather than the toggle type command, but haven't been able to get the discrete codes to do that.
PaulG
I had this problem with my Pronto. I had to relearn some of the codes until they all worked OK.
papill6n
