Chris S
- Apr 9, 2000
- Chris S
The HC3000 is definitely better but as Jim mentioned it may not be worth the difference in price. I have a friend with the 3000 and he loves it. To him the extra expense was worth it. If possible I would recommend demoing the two units, side by side if you could but it's not crucial. If you can't tell a measurable difference then I think you have your answer.
