- Jun 10, 2003
- Josh Steinberg
If you select reply it should automatically bring the quoted single post to the bottom.
If you do click '+quote' it seems to store it in memory and I get a drop down from the top of the screen saying I've selected Multiquote, if you click "- quote" it takes it out of memory.
With my FF (Win 10), after I do the "+ quote" I can see the "insert quotes..." box at the bottom left of the typing box next to "Insert Bookmarks" though it still takes a couple more clicks to get that to populate the reply box instead of automatically doing it like before. I tried just typing my response without the insert quote and hitting post hoping it might auto-populate the selected quotes, but that didn't work.
You're saying you can see the Insert Quote button on Chrome, but not FF? It will be interesting to see if your home computer does the same. I guess it could be FF43, but that makes less sense than a Security Setting on your work computer
Thanks for the tip on hitting "reply" - I was able to do that for this particular note, and viola, your quote appeared a the bottom.
But yes, you are correct about the "Insider Quote" button and how I'm experiencing it.
