Randall Wetmore
- Nov 7, 2005
Adam,
The native resolution of your set is 1366 x 768. I have the KLV-S26A10. This is a very, very fine set, though it took me a while to calibrate it.
Also, because the set's resolution is so high, and it is a fixed pixel display, it is going to be far less forgiving than say a regular CRT unit. Flaws in the picture will be more easily visible, but when HD-DVD comes out, the picture will be that much more stunning and clear.
The ideal settings for this set for me are:
Picture Mode: Pro
Picture (Contrast): Maximum (with the light sensor set to "ON" in the "SETUP part of the Settings menu; this adjusts the contrast of the display via an ambient room light sensor)
Brightness: 53
Color: 45
Hue: 0
Sharpness: Min
Color Temp: Neutral
CineMotion: On
Black Corrector: Off
NR: Off
Backlight: Max
What settings are you using???
Picture Mode: Pro
Brightness: 53
Color: 45
Hue: 0
Sharpness: Min
Color Temp: Neutral
CineMotion: On
NR: Off
Backlight: Max
