HDMI to HDMI 7.1ch Audio Extractor Converter or USB external sound card (1 Viewer)
thxbest
Grip
sean
Hi guys,
I want to connect my AMD Radeon HD6450 HDMI port to my AV receiver 7.1 analog multichannel input, (AVR has no HDMI port), to get newest lossless audio formats, Dolby True HD and DTS HD Master.
To do this:
1 option: Get a "HDMI to HDMI 7.1ch Audio Extractor Converter" like this
http://www.ebay.com/itm/HDMI-to-HDMI...item2c9dc80e5b
2 option: Get a USB external sound card like this
http://www.startech.com/Cards-Adapte...F~ICUSBAUDIO7D
Software decoder is PowerDVD 14.
My question:
Which method works best and deliver the better sound quality?
Thanks for advice
thxbest
Grip
sean
schan1269 said:
Or you could buy an older Onkyo avr(easiest to find used) such as the 605/606/705.
That sounds good.
Is there any used cheap avr that has optical/coax digital out, so it can pass through the HDMI input material to optical/coax out?
schan1269
HTF Expert
Chicago-ish/NW Indiana
Sam
No idea...
Yamaha had some where toslink out was Zone 2. But...they weren't cheap new($1000+ new) and not old enough to reach
thxbest
Grip
sean
The Onkyo 605/606 do not have 7.1 pre out. I want to use it with my Harman Kardon AVR 7300 7.1 input since it has excellent amp section.
Onkyo 705 has 7.1 pre out but I am not going to use the amp as well.
Are there any cheap used processors that can handle the job?
schan1269
HTF Expert
Sam
Occasionally Onkyo prepro show up under $500 from the same era. They were $2000+ new. So no, not really...they are no "cheap HDMI processors".
Unless you found a used Outlaw/Emotiva that was $600 new...and can live with how basic they are.
thxbest
Grip
sean
How about a used NAD T765?
It has HDMI 1.3. The processing, amp section and sound quality are by far superior to Onkyo, Denon, Yamaha.
papill6n
