Kevin C Brown
- Aug 3, 2000
JT- Complicated and won't make sense to anyone but me...
I looked at the 3b-st/nt212, to go with a 9b-st/nt512. I have read all the reviews, seen all the measurements, but to me, the 3b-st/nt212 is just not a substantial enough box. 17" wide, by about 6" tall, by only 9" deep, and weighs about 22 lbs. (I call it a "shoebox" amp.) Bottom line, and Ricky has had a lot of heartache over this , *I* need to be satisfied with the final combo.
So then I switched gears to the 5b-st and 8b-st. 3 channels plus 4 channels, and they actually use the same chassis, so they "stack" more nicely. (I actually have a 60lb balanced power unit on top of the two amps I have now, in the rack under my TV. That would be impossible with the 3b-st/nt212.) But they are really hard to find. And I'd need to find a 412 to go with that 312. Even harder to find. (And I even rationaize the 3 + 4 combo is better for heat dissapation than the 2 + 5 combo.) So I found a brand new 5b-st plus an 8b-st just decided to do it.
Charles- My advice you you is: do *not* go and read all the reviews on Bryton's site. There's no turning back after that. The only other combo I thought seriously about, was the Proceed AMP5 plus either the AMP2 or the BPA-2. But I looked for months, and never did find a BPA-2...
