Douglas Monce
- Nov 16, 2006
- Douglas Monce
Oh I agree completely. Ben-Hur is a great example of a 65mm scan that while it looks nice, is a bit on the soft side. I think someone here said that the only high quality 65mm scanner that they know of is at Fotokem, but that it is very expensive to use. I believe that is one reason that Warner has been doing these HD masters from 35mm elements.DaViD Boulet said:Hey Doug,
I think we all agree with that statement. The catch which I was discussing was that the scanning-equipment used, if inferior, can introduce problems such that a scan from a 65mm element looks softer/worse than that of a 35mm element (even through the lens of SD and HD resolution media). So far, this was the typical situation with SD DVD. Now it looks like the trend might continue with HD media until the studios start to invest in transfers using equipment properly optimized for large-format elements.
Hopefully by the time Ben-Hur rolls around on HD, Warner will have learned this lesson. There's just too much beauty and detail in those 65mm elements to toss away on a transfer that looks less-sharp than a conventional 35mm scan!
Personally I think Grand Prix looks amazing, and I'm not seeing any thing that looks like grain filtering as has been suggested. I don't know if you've had the chance to look at that title or not David.
Doug
