Zipper effect/shaking picture
Discussion in 'Archived Threads 2001-2004' started by sang, Aug 6, 2002.
  1. sang
    sang Auditioning
    Aug 6, 2002
    13
    Images on my TV appear to be slightly shaking from side to side and if I look at the edges of objects, there appears to be a moving "zipper" running up the side. This is most noticeable with a still image such as a DVD menu with text i.e. the text appears to be moving slightly from side to side and looks like there is a zipper running up the letter. I don't know if the problem has always been there because it's not that noticeable while watching regular programming; I happened to notice it after I got the DVD player and was looking at the menus. Does this appear to be a problem with the TV or does it seem like interference/noise being picked up the connections?
    Thanks for any help.
  2. RichN
    RichN Stunt Coordinator
    Jan 15, 2002
    72
    If you never noticed it before and now you do, it obviously has gotten a lot worse, or just started. I would check the connections from DVD to TV/receiver again and try a different type of input (coax instead of optical etc.). It sounds to me more like interference coming from somewhere. Have you moved your speakers recently? Installed a subwoofer? If you disconnect the DVD does it go back to "not that noticable"? Are you going from DVD to TV or through your receiver? If receiver, try a different input (Video3 instead of DVD).
    Hope these suggestions help,
    RichN
