ZELDA Master Quest: Fatal Glitch?
Discussion in 'Archived Threads 2001-2004' started by Brian Kaz, Mar 11, 2003.
  1. Brian Kaz
    Brian Kaz Second Unit
    Aug 31, 2000
    313
    I recently pre-ordered Wind Waker & got the bonus disc and think I have come across a major glitch. In the Forest Temple I beat the four Poes and went down the elevator to get to the boss room in the basement. This is were my problem started.
    In the basement you're supposed to spin the walls until you get the opening with the floor button to raise the gate on the hallway to the Boss room. When I pressed it, it showed an animation of the gate raising, but when I got back to the Boss door Hallway the gate was back down. I went back to the button but it is still pressed in!
    Does anyone know anything about this? As far as I know, I have done what you're supposed to do, but am unable to go any further. I fear that I have just wasted 12 hours of my life!
  2. Kenneth Cummings
    Kenneth Cummings Supporting Actor
    Aug 7, 2001
    852
    I had that problem at first too, but when I kept trying to find the door to see if I was able to enter, I notice there is more then one switch to pushed. So other words, keep pushing down all the switches, it isn't too hard to find (thank god there no Wall Master in here [​IMG]).
  3. Brian Kaz
    Aug 31, 2000
    313
    Thanks. I will investigate some more.
    Though, it begs the question: Why did they show an animation of the gate opening if it didn't actually do so?
  4. David Williams
    David Williams Cinematographer
    Mar 6, 2001
    2,288
    IIRC, there are 2 gates in the basement. The first button releases the first gate and then the second button (behind the first gate) releases the gate to the Big Bad... Unless they've changed it around for Master Quest.
  5. Brian Kaz
    Aug 31, 2000
    313
    Well, I hit a crystal thingy to release the gate blocking the button. then, I pressed the button to release the gate blocking the Boss door...but it didn't release it.
    Hence, my dilemma.
  6. DonRoeber
    DonRoeber Screenwriter
    Feb 11, 2001
    1,849
    Look around for an eye to shoot. It's hard to find.
  7. Brian Kaz
    Aug 31, 2000
    313
    Got it. Thanks a bunch!
