Brian Fineberg
- Sep 1, 2000
the calculator says if the throw disatnce is about 15' then the screen is going to be bigger than 100" diagnol. is this set in stone or is there a way to reduce the screen size a little. Also is the further away you get going to reduce picture quality? I am stuck between mounting on a cofee table(although I think this will be too low for the screen) or mounting on a shelf buitl on the back wall(which will be about 15' fromt he screen on the other wall. Any help will greatly be appreciated....I am oh so close to buying a FP and cant wait just dont want to make a mistake!! thanks everyone!
Brian
Brian
