your opinion....
Discussion in 'Home Theater Projects' started by Gianluca, Sep 12, 2003.
  1. Gianluca
    Gianluca Agent
    May 21, 2003
    31
    Hi everybody... i'd like to have your opinion on the following woofer, i'd like to use it as a powered subwoofer:
    it's a 10" woofer,
    Re 6+6 Ohm
    Fs 19 Hz
    Qms 3.57
    Qes 0.26
    Qts 0.24
    D 208 mm
    Vas 194 L
    xMax 8 mm
    I will tell you later the brand...
    Thank you!
    PS I edited because i posted the wrongs specs... These are the correct ones!!! Sorry for that!!!
  2. Jake K
    Jake K Stunt Coordinator
    May 22, 2003
    132
    What do you plan on doing with this woofer? With only 5mm Xmax it's not going to make the greatest subwoofer, but the Fs is good for that application.
  3. Gianluca
    Gianluca Agent
    May 21, 2003
    31
    Yes, I am thinking about a small subwoofer...
    It's a woofer I could easely buy here, and it's also cheap...
    What would happen with a low xMax?
  4. David Giesbrecht
    David Giesbrecht Second Unit
    May 28, 2001
    306
  5. Gianluca
    Gianluca Agent
    May 21, 2003
    31
    Other opinions on this subject?
  6. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
  7. Gianluca
    Gianluca Agent
    May 21, 2003
    31
    Jack.....
    the woofer I am speaking about is the HS250 by CIARE.
    I was thinking to build a small sealed subwoofer, using a 100W amp. It will be used 100% for music in my small bedroom.
    Do you think I will get satisfying results or should I look at other woofers?
  8. Gianluca
    Gianluca Agent
    May 21, 2003
    31
    somebody else?
  9. Jack Gilvey
    Mar 13, 1999
    4,948
    Sealed won't get you much deep bass, Qts is really too low. Best you can hope for is an F3 of ~57Hz unless the amp has some sort of boost...which many do. Vented looks better, 2 ft^3 tuned around 30z with a 3" x 8" long port looks decent for a music-only system.
