Your experiences with 3803 as a pre/pro and with what amps?
Discussion in 'Archived Threads 2001-2004' started by jeff_coil, Feb 1, 2003.
  1. jeff_coil
    jeff_coil Stunt Coordinator
    Dec 3, 2002
    157
    I am in the upgrade mode again and taking the next step to my ultimate goal of separates! IMO I have built my system in a logical fashion (baby steps first a decent rcvr, second some good amps-hence this post, and third a nice pre/pro-future post[​IMG] ) So it is now time to get some off board power so what I am looking for is some insight/advice/opinions on this questions below that you have tried or currently have in your systems.
    1)How big of sound improvement did you experience with a 5/7 channel amp? What amp was it?
    2) Should I consider a 2/3 channel for the fronts and use the internal for the rears then a 2 channel later? and if so did the quality of the internal Denon amps improve only driving the rears?
    Oh yes this power is routed to B&W CDM’s which in time will most likely be upgraded.
    Thanks in advance
    [​IMG]
  2. Jamey F
    Jamey F Stunt Coordinator
    Dec 20, 2002
    200
    Great question...I am considering doing the same thing. I can't wait to here the comments. I'm looking at the Parasound 1205 or 2205, and the ATI 1505 or 1506 is on my list also. I don't use 7.1 right now, so I will probably go with just a 5 channel amplifier. If I do configure for 7.1 I will set the dipoles to use the internal amps since they will be the least directional sound. I think I'm going to upgrade my speakers first, but after just spending the dough on the 3803, I'm probably going to have to wait 'til I get some money back I overpaid Uncle Sam.
  3. jeff_coil
    Dec 3, 2002
    157
    Jamey, I too am waiting on some feedback. I guess not to many folks have done this [​IMG] No really I hope someone will chime in as I am getting an itchy trigger finger and would value some experienced feedback.
    cheers
  4. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    For what its worth, I have a 3802 that I first started out pairing with a Proceed AMP2 and loved the improvement in sound. Bigger soundstage, better imaging and resolution and not to mention the rock hard bass. I later hooked a B&K REF 7250 for center and surrounds and haven't looked back. I am loving the smooth clean presentation in both HT and music.
    I have no experience with the 3803 but from the specs it looks like it would make a killer preamp.
    Best of luck.
  5. Mark Russ
    Mark Russ Second Unit
    Jun 23, 2002
    341
    On paper anyway, the 3803 looks like it should be just about as good as any dedicated pre/pro in it's price range.
  6. ricky ho
    ricky ho Stunt Coordinator
    Apr 7, 2002
    55
    Hey guys
    I had a Denon 3802 and used IRD 100MB's to power my paradigm studio speakers. My intention was to go separates. I started with three IRD mono-blocks for the front. This sounded like the best improvement. I later added four more IRD mono-blocks to power the sides and rears. I really didn't hear to much of a difference with this up grade. With the seven mono-blocks, I was ready for my first Pre/Pro. I bought a outlaw 950. To date this is the second least expensive purchase next to my SVS 16-46PC+ and best up grade I've made. I truly enjoy listening and watching music and movies though my system.
    Using separates I found my Pre/pro runs much cooler than my receiver did. My amps also run cooler then the receiver's did.
    I enjoyed the 3802 and can only imagine the 3803 would sound great. Good luck in your up grades.
  7. jeff_coil
    Dec 3, 2002
    157
    Thanks everyone keep it coming. Right now I am eying Rotel, Parasound and B&K amps.
  8. James Gallup
    James Gallup Agent
    Jan 3, 2003
    27
    Well Jeff, I was using a Yamaha 2300 rcvr and upgraded to an Aragon 7 channel amp and the improvement was substantial. Depending on budget and the amount of components you can live with, you could start with a good 3 channel amp and add the others as space/budget permit. I do believe you'll hear a definate improvement with outboard amps.
  9. CurtisC
    CurtisC Second Unit
    Jan 7, 2003
    369
    I have the 3802 w/parasound 1205a into klipsch rf7's,rc7,rs7,rsw 15 and this is the best combo I have found in its price range.I use 3802 to power rear surrounds only,does quite well.The trigger on is nice also.
  10. rob-socal
    rob-socal Agent
    Nov 4, 2002
    45
    I'm in the same boat, but my HTPC project has me financially incapable of upgrading. Leaning towards Rotel 5 channel or Anthem MCA series 2 channel; some day. Please report your findings.
    -RJ.
