yikes, watching HDTV at +20DB's, normal cable at -10DB swtich channels and kill ears
Discussion in 'AV Receivers' started by Dustin Wind, Sep 20, 2003.
  1. Dustin Wind
    Dustin Wind Stunt Coordinator
    Aug 19, 2003
    158
    What did i do!
    When i watch HDTV i put it about + 20 DB or so.
    When i put it on digital or regular cable i cannot hear it at all with this level.
    I need to crank it all the way to the highest my Kardon 325 will go to hear digital/normal cable.
    If i switch it back to a HD channel without turning it down...you cannot imagine the sound that comes out.....my girlfriend almost started to cry it was so bad...both our ears were ringing for 20 minutes.....not to mention i hope my new speakers are OK.
    So what did i do? It wasn't like this a few days ago. Even at full on the receiver i can hardly hear any channel except HD.
    I have a Kardon 325 and 7 JBL speakers if this helps.
  2. Dustin Wind
    Aug 19, 2003
    158
    Ok, it appears that its regular cable only.
    Digital cable is pretty loud and so is the HDTV.
    I can hardley hear the regular cable.
    Any suggestions?
  3. Scott Kriefall
    Scott Kriefall Second Unit
    Mar 9, 1999
    332
    SLC, Utah
    Scott
    Are you using the analog outputs from a cable box for the non-digital cable channels? If so, check the volume level setting on the cable box.
  4. Dustin Wind
    Aug 19, 2003
    158
    Thanks Scott. Silly me
